evacuk
Mineral Clutch fluid or DOT4 or DOT5?
Let me first explain the background to my questions, due to an injury to my right hand and elbow I have to ride with my front brake on the left hand handle bar and the clutch on the right hand handle bar. This normal means using the clutch master cylinder as a brake and the brake master cylinder as a clutch. I have made this conversion in the past on my 04 K1200LT with out to any problems expert for bleeding the brakes but that is another story. I now am running into a few problems with my new BM a R1200GS 54.
Firstly can any one tell me the size of the piston in the clutch master cylinder is it the same or close to the size of the brake master cylinder piston?
Secondly, the GS clutch use’s mineral clutch fluid V10 I believe, is this the same as the Mineral fluid sold in Halfords as LHM Plus . ?
If I use DOT 4 for my new braking system will it affect the seals in the clutch master cylinder, now the brake.
If I use DOT 4 in the new clutch system will it affect the seals in the clutch slave cylinder? If I use Mineral fluid will it affect the brake master cylinder, which is now the clutch.
I have been told that DOT5 (not DOT5.1) a silicon synthetic fluid is compatible with both DOT4 and Mineral Fluid , can any confirm this?
If true this would be the answerer to my problems.
If I have to change my clutch slave cylinder is there another model GS which uses DOT4 which is a direct swoop for a R1200 GS
err DOT 5 isn't compatible with DOT 4 or 5.1 as (as you say) it's a synthetic silcone based fluid that needs changing every 5 mins
