Missing bolt?
lagauk
Norf Laandan COYS
Am I missing something here? Have only just noticed this. Stupid question but should there be a bolt in that hole and if so what size?
Yep reckon you are indeed missing a bolt, I will guess it should be 6mm although without taking it out don't know the length IMG_0946.jpg
Just been out to have a look,
yes there should be a bolt in there.
check its not sheared, and you have half a bolt in there ;)
If not RealOEM, and order a new one
Mart
If you only need the one just call your BMW dealer and have one posted to you. Use a drop of thread lock to make sure it stays put.
I swapped to stainless hexheads then swapped back to stainless steel Torx bolts, I decided it made more sense than carrying two sets of tools to cover the various ones I hadn't changed as well :blast
OP - if you want one in stainless PM me your address and I'll pop one in the post.
Stu.
Appreciate the offer Stu. I think I might have an Allen bolt somewhere which will fit, same as the one holding the cylinder guard in the pic.
Hadn't considered a sheared bolt so will have to check that out on the weekend. Thanks for the heads up Mart.
Makes sense to have similar bolts wherever you can. Good idea less stuff to carry.
Many thanks for the feedback fellas.
Lag
