Hi Spud did you find out what the issue was with not being able to change modes on the fly. I’m having the same issues. Also if I stall the bike I have to put it into neutral to restart, where’s as normal you would just pull in the clutch.
It will be the clutch switch I have the same problem. I removed the switch and cleaned it, it started working correctly for a week or two then its the same again. Need to order new switch.
