Mart75 Member UKGSer Subscriber Joined Mar 24, 2013 Messages 68 Reaction score 8 Location Somerset Sep 30, 2024 #21 Sounds like the switch might be gone then - is that an audible click just as you pull in the clutch - will go and have a listen if it stops raining!
Bigcats Well-known member UKGSer Subscriber Joined Nov 19, 2022 Messages 12,118 Reaction score 12,103 Location Portsmouth, England Sep 30, 2024 #22 When I road in today I can change modes by simply Changing mode then coming off the throttle No clutch etc
Jer Member UKGSer Subscriber Joined May 29, 2016 Messages 31 Reaction score 2 Location Aberdeen Oct 24, 2024 #23 Barnoe said: There is a microswitch in the clutch. It should click when you pull it in. This disengages the cruise control and also changes ride mode. if it doesn't and you can only do it pushing the throttle forward, the switch has gone. Click to expand... I had the same issue, found the clutch micro switch was loose and just needed tightening.
GSian Well-known member UKGSer Subscriber Joined Aug 14, 2020 Messages 1,087 Reaction score 592 Location Yorkshire Oct 25, 2024 #24 Try starting the bike in gear with the clutch lever pulled. If it won't start it's the switch or switch actuator on the lever that's not working.
