monolever indicator switch goosed
The Other PaulG
Still searching
Surrey, England
The switch has been a bit iffy ever since the 'day of dust' on the Plain at the Hograost.
However, the part of the switch that you use your thumb against became very gritty and has now fallen out :rolleyes:
Any advice on the servicing of these handlebar units before I take it off and it falls into the obligatory 20 pieces?
I can't help you directly, but try to repair it as new ones are eye wateringly expensive.
The update...
Ok so this is an interesting one.
Forearmed with Haynes' wisdom "bear ye at least £80 for unobtanium, all ye who enter here, as this unit is amongst the unfixable..", my findings were in fact quite interesting.
When I stripped the switch into its 2 halves, and clipped the indicator lever back in, it worked fine. Excellent! On re-assembly, it was gritty and reluctant/jammed solid once again... hmmmm....
On closer inspection I saw that there is a channel for the red/blue wire to sit in and mine was not sitting in its channel:
... so after snugging it into place and re-assembling, all worked really well once again. :friday
I guess that bikes like these have probably had so many owners and so many strip-downs, this is more than likely to happen.
Moral of the story? Just because Haynes says it's goosed, it's still worth a look. :rob
PG
well done you!!:beerjug:
Just shows some "sealed for life bits" can be resurrected with a bit of investigation and prudent poking!!
after seening that i will give my gs one a go and try to get dip beem to stay on.
