Mount for a Chigee
Wapping
Moderator
Wapping, London
I already have my Garmin XT, mounted above the speedo binnacle thing.
What I am on the hunt for is a suitable mount, so I can put a Chigee device onto the crosspiece of the handlebar. I had hoped to use the steering column, but the crosspiece obscures it.
One caveat…. I am no fan of Rammount’s scaffolding. Something that bolts onto the handlebar clamp might be good, I guess, assuming it does not then render the ignition tricky to access.
Thanks for any suggestions.
PS The mount on the bar, is a very nicely made Migsel mount, which I have used on assorted bikes over the years. A Tosser on the forum, very kindly machined a bespoke cross-bar for me, to accommodate the smaller diameter of the Migsel.
Something like this, I guess, assuming the plate is suitable for the Chigee?
I now learn that there is a suitable mount in the Chigee box. They think of everything, these Chinese.
I’d tell you to think out side the box , but actually opening the box would have solved all of your issues .
If you decide you don’t want it , I’ll have it off you as need one for my Voge.
Having at last opened the Chigee box, there is indeed a suitable mount. My thanks to Biggles for pointing this out and, indeed, for alerting me to the significant discount available when I bought the thing months ago.
First things first though…. To put a bit of tape to stop the plastic spacer ring from sliding around and annoying me.
Then to find a suitable live trigger wire. I’m surprised to read Biggle’s report that the trigger wouldn’t fire from the Thunderbox. It goes live with the engine firing.
