Ever since it was announced, many have asked questions but one important was still how to mounting it on the bike.
I have seen inside the Zumo 550 box along with the RAM mount set-up to used by bikers.
The mount kit is borne out of three parts;
RAM-B-309-1 + RAM-B-201-A (short arm) + RAM-B-202.
The RAM-B-202 round base attaches on to the four hole fix pattern in the Zumo cradle (no surprises then).
The RAM-B-309-1 has spacers and 60mm screws (set of M6 and 1/4") for attaching to Goldwing's and Pan ST11/1300 onto the clutch or brake reservoir clamp brackets (again no surprises) ... but here is the twist .. there is also the 25mm (1") u-bolt for attaching onto conventional tubular handlebars using the RAM-B-309-1 bracket.
But many will choose or opt for a position not necessarily around the handlebars, say on the oval rail (above the clocks) on a 12GS/12GSA. At first sight it does appear that this kit with a RAP-319 shim adaptor will go around but will need to be tried, but the option may be to get a RAM-B-231/231Z with a RAP-319 which we know does work well.
Sports bike riders will be scratching their heads.
