Humbug
Arrived safely yesterday. Thanks very much!
Mick_rw said:impressed, tested my muffs in the rain today, when I returned home had to remove them to drain the gallons of water that had accummaletd inside them....what did I do wrong, and yes I did follow the installation instructions....![]()
Worth a try think of that and when I installed them I did cable tie the mirror stalks....Shep said:I've not had any problems with mine, but it looks as if the rain could hit the mirror then travel down the stalk, i've seen people cable tie the muff to the mirror to get a sealWorth a try
Shep
Matt Gibbs said:Mick,
As well as cable tieing the muff to the mirror stalk I made sure the velcro seal was pointing downwards where possible before using the elastic cord . Are you sure you didn't leave any little gaps in the velcro where rain could get in?
I tried mine a few time before I got what I thought was a good seal.
Brilliant as they are they exacerbate my carpal tunnel syndrome due to the slight change of angle at which I hold the grips to the point where 18 miles =
numb right thumb and first two fingers whereas 100+ miles wasn't a problem so sadly they have had to come off
Regards
Matt
had a look for possible leaking points etc...but I will admit I don't feel happy with them in general...feel they restrict my hand and arm movement, may be I should give them another go...or buy a pair of good waterproof gloves. They are a well made piece of kit by the look of them, but am beging to think they are not my for me....will think about it a bit longer before I decide wether to use or sell them.Matt Gibbs said:Mick,
Regards
Matt
xpi0t0s said:how about an update Steptoe - who's sent you cash and isn't getting the stuff?
- I phoned GS Shop yesterday and that's what the guy there told me.DaveGSCymro said:I think he is away at the moment.
hi mate,i have'nt sent a payment for a shitebag but i still want one and i want to do the workshop thing,are there any left?shall i put a cheque inthe post for both?Steptoe said:If you asked for a set, and sent the payment before i went away ( 10th Nov), you should have recieved your muffs .
How simple is that.![]()
