Nav V
stick
Lord Lytteltons Door Mat
Morning , can anyone tell me if you can use a BMW Nav in a standard Zumo bike mount as wish to lend one to a fellow but before I order the mount ( Garmin) as he is in a KTM I thought I would check.
Thanks in advance.
Depends which Zumo model(s) the mount is for…
Thanks , it was to used in the cradle that fits the Nav v , meaning Would the standard cradle work for the lm series with the Nav v as it’s from the bmw with the thumb wheel , it more for the power connection.
Stick, I’m afraid your post #3 doesn’t make sense.
To answer your question, please tell us:
1. The specific mount you want to use. In other words, which GPS device was the mount used with.
2. Which specific GPS device you now want to put into the mount.
Thanks.
It will be a long thread and the answer will be no.
If what you mean is can you fit a BMW mount to a non-BMW bike the answer is yes.
I’ve had the BMW 4-button mount on several non-BMW bikes and used my Nav5 in it.
You can use the BMW mount with some Garmin devices - Zumo 660 for example - so a Garmin mount would work for a Nav5, as long as it’s for a compatible Zumo, such s the 660 s Lord Snooty says.
Wapping’s questions would allow a correct/certain answer…
