New Basecamp
Redboots
Member well-known
Deep in the Vosges du Nord
I was reading on another forum about Basecamp 4.1.0... Mine was at version 3 something and auto-update said it was up to date :nenau
Link in case you want it.
Search/find is revamped.
:D
Mine was the same. No mention that Basecamp should/could be updated but a quick check to Garmin showed the update. I wonder if they pulled the option to auto update when they realised that the new one was causing problems? That way you'd stay which ever version you currently had. Sounds a bit too sensible for Garmin though.
I can't be bothered trying to retrograde it so I'll just not use Basecamp for a bit. If they can sort it within a few months I'll survive! :mad:
Is it possible to still get the older versions of basecamp? I've downloaded the latest version and that won't run at all. :blast
The MSI installer will barf as you are trying to install an older version...
I uninstalled 4.1.0. with Revo. Now have to reinstall my maps :censor:
