No clutch Gs 1100
The Heff
Co. Down, N.I
Hi all.
Took the 1100 out today and after a few miles I had no clutch, like a broken clutch cable, but it isn't that
The cable is fine at both the handle bar and gearbox as there is movement as normal.
Could there be a fault in the release mechanism preventing the clutch from engaging?
Any ideas:confused:
Ps full clutch replacement 7000 miles ago
Hi all.
Any ideas:confused:
Check the adjuster bolt is still in place or may have become unscrewed at the rear of the gearbox.
Or maybe the clutch actuation arm/lever has snapped. Quite a common thing on 1100s. They are cast ally. It happened to mine and was replaced with a steel one from Motorworks
Turns out the Actuation arm had snapped as mentioned by Mark:bow
Parts
Rang Hursts today out of interest, £128 WTF but none in stock anywhere in UK, so need to be ordered from Germany with no delivery date:eek:
Bought the Stainless steel replacement from Motorworks for £30 less and delivery in 2/3 days:thumb2
Thanks for the pm Dr Farkoff:clap
Hope to be sorted over the weekend:aidan
Clutch
All sorted:thumb
Alex is that Locknut "nipped" up ?? probably an optical illusion but there looks to be a gap
Good Luck and Many miles for her :aidan
I never fitted my steel replacement. Is it possible to do it with the swinging arm in place? I would guess not as even adjusting it is a bit of a fiddle, but you never know!
Havent had it out of the garage yet. Will make sure all is ok before taking it out.
Thanks for pointing that out:blast
Managed to get it out without removing any thing. Getting it back together was another saga, everything off, caliper, wheel, shock, etc all for 1 feckin bolt:mad:
