R1100GS 1999 110,000kms : Strange - no rev counter today ? Any thoughts what to check first ? everything else seems to be working fine . Is this just likely to be a fuse ?
will check that first. It's a tricky one to test because I need the tank off to get at the wiring but I need the tank on to run the engine to see if it's working or not
Hmmm.... finally got round to getting under the tank and looking for the problem but I'm damned if I can see anything out of sorts.
I can't actually see an earth on the right side of the beak but I can trace the wiring back from the tacho , down the loom under the tank (more or less) and it all looks OK.
Has anyone ever experienced tacho failure? Could be the tacho itself ?
