Oil capacities, engine, gearbox and final drive?
Timpo
North Wales TRF
Cheshire, England.
I've got a couple of hours spare here, and I'm not at home, so can someone give me the oil capacities of the engine, gearbox and final drives.
If I can find enough oil, I'll do a change......:augie
Timpo.
Engine oil 2.50 ltrs sump plug 22 lbs/ft
Gearbox oil .80 ltrs gearbox sump 19 lbs/ft
Rear bevel drive .260 ltrs drain plug 13 lbs/ft
Use 20/50 engine oil and I believe you use ATF in the transmission ( I'd use GL5 80/90 myself )
P.S. If you are doing the oil filter, obviously a touch more oil and those pesky three bolts to the filter housing are only just nipped up ( 6 lbs/ft )
