BurtieBoy Active member UKGSer Subscriber Joined Jan 20, 2005 Messages 460 Reaction score 2 Location Cheltenham Jul 29, 2009 #1 On my GSA I have noticed oil leaking from around the black plastic ring on the centre of the rear drive unit. Is this a seal that's gone? Is it easy to repair?
Sgt Bilco Dream Maker Moderator Moderator Joined Jun 10, 2005 Messages 17,412 Reaction score 1,973 Location Evesham, England Jul 29, 2009 #2 BurtieBoy said: On my GSA I have noticed oil leaking from around the black plastic ring on the centre of the rear drive unit. Is this a seal that's gone? Is it easy to repair? Click to expand... Yep, the seal is gone. It`s only a quick job and you`ll get it done under warranty if you have it
BurtieBoy Active member UKGSer Subscriber Joined Jan 20, 2005 Messages 460 Reaction score 2 Location Cheltenham Jul 30, 2009 #3 Cheers - I'll get on to having it fixed. Unfortunately no warranty so I'll have a look at it myself. Burt
RogerJ Registered user Joined May 20, 2005 Messages 127 Reaction score 0 Location Toronto, Canada Jul 30, 2009 #4 BertieRoy......if you have to do it yourself then here is a link that should help. Make sure you get the proper OEM gasket. Cheers! http://www.advrider.com/forums/showthread.php?t=418242&page=2 BTW the new BMW released spec for the final drive lubricant has been reduced from 220 ml to 180 ml.
BurtieBoy Active member UKGSer Subscriber Joined Jan 20, 2005 Messages 460 Reaction score 2 Location Cheltenham Jul 31, 2009 #5 Thanks Guys, This is a common problem judging from the material on this site and AdvRider. I'll get a new seal at the weekend and I'll have a play. Burt
