Power socket position
Captain Beaky
Stroud
Anyone know where the second power socket is fitted?
You know, the one up on the instrument cluster?
A photo would be useful,
Cheers,
Mike.
Captain
On the beak, just forward of the the tank joint either or both sides if you like. Takes 1 hour or so.
Whip the tank off, drill the beak with a flatbit and wire directly to the battery, I soldered a ring connector to a short ( 6" ) 2.5mm cable and then fitted a triple connector block to the other end so you can connect other things to the supply i.e. alarm, lights, satnav etc
Socket 2 me 2
Definitely needs an in-line fuse.
From the thread about chargers, sockets etc. available from www.farnell.co.uk
Part Nos:
658431 for the socket
658376 for the plug
