red1 Registered user Joined Nov 5, 2007 Messages 2,016 Reaction score 2 Location Lincs, England Apr 21, 2016 #1 Is the dashboard aux socket OK for powering an Airman pump or is there a canbus restriction? ...... from the dark side this was sent
linssen Registered user Joined Apr 4, 2011 Messages 23 Reaction score 0 Location Cambridge, England Apr 21, 2016 #2 red1 said: Is the dashboard aux socket OK for powering an Airman pump or is there a canbus restriction? ...... from the dark side this was sent Click to expand... It draws about 10a so the canbus will trip. Best option is probably fitting a second accessory socket straight to the battery with a fuse inline.
ymfb Well-known member UKGSer Subscriber Joined Jun 8, 2012 Messages 7,142 Reaction score 447 Location Salisbury Apr 21, 2016 #3 trips after about 2 seconds, need to make a direct connection to the battery.
red1 Registered user Joined Nov 5, 2007 Messages 2,016 Reaction score 2 Location Lincs, England Apr 21, 2016 #4 Cheers Sent from my Nexus 6P using Tapatalk
AberdeenAngus Well-known member UKGSer Subscriber Joined Jul 23, 2009 Messages 14,289 Reaction score 46 Location Aberdeen Apr 21, 2016 #5 linssen said: It draws about 10a so the canbus will trip. Best option is probably fitting a second accessory socket straight to the battery with a fuse inline. Click to expand... This. Also means you can use a bog standard battery charger.
brianmaslen Well-known member UKGSer Subscriber Joined Oct 27, 2007 Messages 1,539 Reaction score 92 Location Royston, Hertfordshire Apr 21, 2016 #6 My Airman came with a connector for the battery which I fitted and just tuck out of site and protected behind the panel, just fish it out when needed.
