Just to say that i drilled the 22mm diameter hole in the silencer baffle plate and then removed the snorkels. Well i was a little hesitant if truth be told as it would be impossible to fill that hole again as it is about 300mm from the end of the can. Anyway, fired her up and went for a spin. The result seems to be a very noticable positive engine response with a nice barking sound when cracking the throttle open. Thanks for your advise, it seems to have worked well. The only doubt i have is about water being driven into the air filter and airbox, is this likely to cause problems? or will it just escape through the rubber valve that is situated in the base of the airbox. Thanks once again, Stash.
