r1100gs indicators
cyprys
west lothian
Hi all, I am having problems with the indictors on my 98 r1100gs. The other day they started flashing a lot faster than normal. My first thought was I had a bulb out , which wasn't the case. Today I have been checking the various connections and found nothing. The hazard side of things flash normally. Would anyone have any idea what the fix may be? If I put another 21w bulb into the circuit they flash at a normal speed on that side.
Thanks in advance
the faster flash rate happened to me a few weeks back I thought I had a bulb out but no, I removed the flasher relay and sprayed switch cleaner into the socket and relay pins (btw when it was flashing fast it was only the indicators hazard flashed at a normal rate )
after the spraying all work as normal
this what I used servisol switch cleaner
http://www.ebay.co.uk/itm/2-x-Servi...575?pt=LH_DefaultDomain_3&hash=item3f32fbf47f
