R1100GS Injectors
punisher84
Member
Warrington
Hi guys
I've got a failed injector on my 2000 1150gs but I have the old injectors off my 1100gs after upgrading them to the Tills 1200 ones. Will the 1100 injectors work in my 1150gs?
Hi Steptoe
I was wandering if you may have some advise my 1150GS has a surging issue at steady revs and seems to be using fuel at a ridiculous rate. full tank of Ultimate BP down to the light in approx 100miles.
Any Guidance will be greatly appreciated.
Hi Steptoe
If a TPS has problems a couple of the symptoms are increased fuel consumption and uneven/flat running.
I have a pair of matched injectors from my 2002 (manufactured date, registered 2003) single spark. :marc
Thanks Alan, i may need them. My old mans hopefully coming this weekend to fit a new slave cylinder so he will run some proper tests.
