petkostas
My bike is really stubborn when cold, if i start it without revving it will die, I need to start hold on the throttle for a while and wait, even sometimes with 1 temperature bar on the RID it will die!
When it dies I can see the battery icon lightly flashing, after many tries (without throttle) sometimes it catches but slowly dies after a few seconds...
Lately it does this oftenly!
I have also noticed that if I start cold and move the bike I can ride (but I need to slip the clutch a lot to move otherwise my bike stalls) but once I clutch to change gear my bike dies (as the RPM drops for shifting).
Problem vanishes after my bike is warm, or if it has traveled some distance!
I changed my battery today, to an odyssey just in case...but problem still remains, cranked after installing battery, bike starts but if not on throttle it dies...
I have done the throttle trick (open 2 twice, turn off, turn on) but still no good (apart sometimes when it seems to come to life more easy).
I also experienced a stall! twice today (before replacing battery), engine would stop! It was running, everything was on, it just would not respond to throttle!
after a few meters it came to life (it seems as it came to life when I down shifted).
Second time it did I checked to see if my RPM's would rise with throttle, but did not, it just responded as if the throttle cables where cut.
P.S 500 Km's It was serviced, fuel filter replaced, air filter replaced.
