dippy
hi folks, need your assistance, guidance, knowledge, prayers etc
r1200gs, 99,000 miles has decided to start an oil leak. I've had a look and the source seems to be from the upper part of the engine, well that's where the leaked oil is pooling anyway but the leaked oil is getting splashed all over the place and ends up dribbling off the bash plate. seems the leak is in its infancy, perhaps in the past 5,000 miles.
Here's the pic, you can see the oil pooled on top of the engine, would appreciate any advice here folks, I can't quite see where the leak would be but I'd loath to remove the engine and then find out i didnt need too!
..... r1200gs, 99,000 miles has decided to start an oil leak. I've had a look and the source seems to be from the upper part of the engine, well that's where the leaked oil is pooling anyway but the leaked oil is getting splashed all over the place and ends up dribbling off the bash plate. seems the leak is in its infancy, perhaps in the past 5,000 miles.
, not sure if it was the oil pressure sensor washer or the oil cooling pipe o ring as when i changed the o ring i checked the oil pressure sensor torque and maybe it wasnt tight enought
but anyway it was one of those so happy days.
