England-Kev
so apart from the springs, and oil seals, is there anything else I need to order?
The faster you go the less weight you have on the front end
Your size, (weight), should not really materially affect what happens to the front forks
I can't find oem springs for the ST?? maybe I will try the progressives from motobins then
if you knew someone.31421237232 st compression springs
realoem site
you could get some r80g/s forksif you knew someone.
