Rear wheel splines lubricant?
John Roberts
North Wales
I have been using LiquiMoly grease for yonks but read recently that the stuff to use is Optimol. So, what should I be using?
As an alternative, I use Hondamoly 60 on my Brick - like Optimol, it has a higher percentage of moly (60%) than typically found in other brands.
A tube of Optimol will last you a lifetime..and is obviously also for the gearbox splines ( you do lubricate them every year, don't you?:D ).
Every YEAR? :eek:
Don't you know you have to lube them every coffee stop?
You vandal, you. :thumb2
Just found that the Rider's Handbook recommends Molykote BR2 or Liqui Moly LM47L, but that was way back in 1982, it seems Optimol is more favoured these days- I'll go with that, I think.
Thank you, folks.:beerjug:
