obewan
i have looked at the various threads but they don't quite answer my concerns.
Symptoms: variable amount of play in the rear wheel from none at all to 2 - 3mm when held at 12 and 6 o'clock position. Also when there is play i can here a clonking sound when riding very slowly <10mph. I also think that i can feel the clonk if I lightly touch the rear brake.
But as i say sometime the wheel seems to be rock solid no play whatsoever. Further there is no straight answer as to when there will or won;t be play. that is it does not seem to come about when the bike is hot, or disappear when cold.
THe model is an 04 with a mere 30k ont he clock. last year i had the FD oil replaced at service, and I asked for the bearing to be checked.
Today on hot roads, good tarmac, good tyre pressures etc the back end suddenly lost all grip as i tipped into a right hander at about 70mph. It then fishtailed ac ouple of times before coming back into shape. When i stopped the play had reappeared, and there after I just couldn't get any decent feel in bends (or was that my mind just playing tricks)
So please is the amount of play a fixed thing or a variable one. Will get the bike back to the dealer for a check, but lost all confidence in the rear end today and ended up riding even more like a pleb than usual.
thanks
thanks
