Why would you think it was the "rectifier"?? The charge management is all done via a car type alternator and managed via PWM from the ECU
What actually happened ?? Driving along Dash and lights all showing ?
Engine goes into engine breaking mode? Dash stays on or turns off ?
Engine not running when you stop?
Will crank over ?? Sluggish? or as it did when you started the day ??
I think the recovery dude thinks its a standard Jap bike set up Stator rotor and rectifier regulator
Anyway I think you need one of these 16148523697 or to at least get a duff one and make up a bypass lead to carry with you It is likely to happen again!!
My first move would be to look in where the FPC sits in the fuel pump well left side front of the fuel tank assembly
Make sure that there are no nicks in the shaped seal (Marked with the star) and there is no water in the well below?
If there is dry it out and use silicone grease on the seal and connector and try as best you can to keep water out
