First of all, sorry for asking this because I am sure it has been discussed here many times (just could not find it during my quick search).
I am now 2 years in my RTW (I think it will take around 4 years). Currently in Oregon, USA.
I have had on-off problems with my ABS since Indonesia, sometimes ABS fails to work, sometimes it works (just normal stuff).
Now servo has totally failed from rear brake (front servo and ABS works) and braking power is really weak.
I am thinking that I will bypass ABS unit (rear line) and convert rear brakes to "standard" one (without ABS) by just one simple brake line.
My question is: Should I make a loop brake line for the ABS-unit (combine incoming and outgoing lines on ABS-unit) or should I just plug both lines on ABS-unit?
I do not care if brake light flashes in my dash, I have already fixed it with black tape
I do not want to spend $2500 for new ABS-unit which will fail again (I have already second unit in my bike).
At the moment Modulemaster cannot fix unit, because they do not have parts available (when they have parts, cost will be around $700).
I will be heading to Alaska in few weeks and I would like to get my rear brakes back before this, so all help would be appreciated
-Hemuli
www.whereishemuli.eu
-Hemuli
