removing mirrors 2002 1150gs
AndyMac
North Lincs
Good morning, could someone explain how to remove the mirrors please I have some Rizomas to fit
TIA
Andy
From another forum
Pry off the plastic cap on the housing at the base of the mirror's stem (located on top of the handlebar housing) to find the screw. Use an allen key to tighten or loosen the stem - it's threaded just the opposite of conventional.
The left side mirror is conventionally threaded and the nut is on the bottom of the stem. Go figure.
From another forum
many thanks for that
Not got one but blessed google comes up with this- no idea if helpful-m could be worth a try.
"Pry off the plastic cap on the housing at the base of the mirror's stem (located on top of the handlebar housing) to find the screw. Use an Hex key to tighten or loosen the stem - it's threaded just the opposite of conventional.
The left side mirror is conventionally threaded and the nut is on the bottom of the stem."
My 2001 1150 the mirror is a 7mm Allen screw, I had to buy one as not in the set. Good idea to keep one in your pocket for emergency use.
