NIck Jackson
I just bought a second hand remus can and Y- piece and have a question about how it should fit - forgive me if this is old news....
The can is a Revolution model with a rubber bush in the mount. Is there any way to mount this without it rubbing on the foot hanger bolts? Have I just not got it on straight or am I missing some spacer? Crawling back through old threads there seems to be a suggestion that earlier bikes need a different mounting on the exhaust (mines a 'W' 2000). By the time I've added locknuts on the rear of the hanger fixing bolts I've had to add about 6mm of washers to space it away and it is still touching one of the bolts.
Any suggestions will be much appreciated....
mine did not fit at the can end so i made a brkt out of ally now it sits 25mm lower and in 10mm or so and is well clear of box.
