Thanks for the *varied* advice guys. I'll check out the suggestions - even buying the same again - but I live in the south of France and a battery that can't handle the typical lowest temp of 3C is not up to much, even if it's not used more than once a week.
As for sticking it on the Optimate every ride... well, that's not practical from the fourth floor of an apartment (but, you're right, I didn't mention it)
Here is another consideration when replacing your battery, ever considered these:-
"HICAP2 starter upgrade kit -
"HICAP stands for High Capacity Oxygen Free Copper DC Distribution Circuit and the main part of this kit is a pair of uprated highest quality starter and earth leads. These leads are a better spec than your bike had from new and by flowing more current to the starter (and completing the circuit using a better quality earth lead) your bike will start more easily resulting in less starter wear and extended battery life. These will flow more than 70amps where your starter only draws around 55amps so these are well specced for your Guzzi(from http://www.gutsibits.co.uk).
I fitted these to my Guzzi V11 along with a new battery, cannot actually say if they add anything to the starting effort but they are about twice the cross section of the original cable which are not much bigger than bootlaces![]()
My 1200's battery died this year. I suspect it's the original battery from 2005
So I replaced it with this. IIRC it was £27 (trade price). Notice the similarity between the two of them...
BMW wanted over £100 for an OE battery![]()
Does beemer warranty cover batteries ??
Think my battery is on the way out, not sure but if it is duff i will replace with this i think. http://www.ebay.co.uk/itm/321029435399?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
For under another £9.00 you could have...
http://www.ebay.co.uk/itm/MotoBatt-...33?pt=UK_Motorcycle_Parts&hash=item23221bbed9
Yes - If it's a genuine BMW battery, not more than two years old and it's failed due to a manufacturing fault .
