notagser
At some point before Spring, I’m planning replacing the main clutch line on my 2000 R1150GS.
The fitting at the slave end is rusting, and I expect the lower end of the hose will be deteriorating under the rubber sleeve.
I recently fitted a set of Goodridge black “shadow” brake lines, so was planning to get a clutch line to match. Unfortunately Goodridge can’t supply one……… They say the pattern of the one supplied to Motorworks is owned by them, so couldn’t do one direct to me. They suggest Motorworks could possibly order the black version. I’ll investigate that after the holidays. (Over £100 for a Motorworks/Goodridge line though)
Does anyone have experience of the cheaper hoses supplied by Probrake, Motobins or Sherlock?
Sherlocks looks like it could be manufactured by Hel. Motobins seems to be a venhill bolted one.
https://www.james-sherlock.co.uk/sh...2/clutch-control-hydraulic/clutch-line-detail
https://www.motobins.co.uk/displayfinal.php?q=29403S&topsearch=1&go=GO
https://www.probrake.de/Steel-Braided-Clutch-Hose-for-BMW-R-1150-GS-R21-1999-2001-with/no-ABS-II
