Replacement heated grips
JonF
Surrey, England
I need to replace a duff left hand heated grip. Just a thought. Is it possible to replace it without completely removing the tank? When I swapped the battery it was pretty easy to do by just propping the back of the tank with a lump of wood. Any chance of doing the same with the grip connectors? I don't really know how far back under the tank they are. Anyone tried this?
The connector for the grip is under the front of the tank on the frame amongst the control and instrument plugs.
Just pop the tank back a bit to reveal the whole lot.
Depending the year or model of your bike ( you haven't specified) it's either a white plastic block that holds both grip wiring/plugs, or the later bikes black individual plugs.
Worked out well in the end
Exactly as you said Mr Steptoe, thanks. Easy job apart from routing the wire through the bars. What I did to make it easier was fasten a bit of thin garden wire to the connectors of the old one, and pulled it through when I took the old off. Then the same in reverse to pull the new through the hole in the bars. Job done. Just in time for the chilly weather next week. :D
When my left heated grip stopped working, I balked at the £50+ cost of a replacement & set about stripping down the old one. I figured that the only reason it would stop working was because the wire element had broken somewhere underneath the grip.
Careful cutting with a craft knife was all that was needed to get the grip off. The element, itself, is wrapped in a brown paper tape & this was also easy to remove with the craft knife, & revealed a plastic tube with a channel running a spiral along its length. This is what the wire element sits in &, sure enough, there was a break. I carefully wrapped this wire back in it's channel & secured the loose ends with some tape, after lining them up so that they were virtually touching each other. A soldering iron & a tiny blob of solder reconnected the ends properly & after it all cooled down, I wrapped it in electrical insulating tape & put a new right hand grip over the top (hairsprayed in place).
That was 4yrs ago & it seems to be holding up quite well...
