DIY Repair Easy ish
Found resistance wire had failed where its crimped to the flexible wires under the grip. Made new joint with fuse wire and soldered up. Used self-amalgamating tape brought from this site to bind over resistance wire, then used hair spray to lubricate when fitting new Renthal grip.
Biggest problem was separating the old rubber grip from the plastic twist grip it seems on 07 models these parts are fully bonded together. Ended up having to shave off loads of small bits of rubber with craft knife, very tedious to do and all the time risk of damaging the resistance wire.
Anyway job done and both hands now warm as toast.
