Right Side Cam chain Tensioner
Smudge
Kent
1200 GSA Late 2006 model 51000 miles (so far).
So .......What causes the Rattle on start up, :blast only a second or 2 until the oil pressure kicks in. :D
Narrowed it down to right side tensioner, removed it but it looks fine. :nenau
Thinking it may be a weak tensioner spring so ordered a new one, see if that helps :augie
Any other ideas :D
If its been parked on side stand, oil drains down from the right. Try parking it on centre stand with a plank under the LHS so it leans a little to the right If the rattle stops you'll know its just a feature.
Thanks chaps :beerjug: I will ignore it :D
I will let you know if the new spring makes any difference :thumb2
