- Joined
- Nov 5, 2015
- Messages
- 13,439
- Reaction score
- 5,660
If it was just serviced, check there’s no signs of leaks around the oil filter, drain plug and rocker covers just in case, if they’re dry, as Onahi says, the LCs don’t use oil
Because it used it. Nothing wrong with that.The question for me is why does the bike require any oil ?
All four of my Lc's have never used any oil between services ?And for the warning to show, must mean very low on the window ?
Where's it gone ?
That's not normal for this Motor. The 1150's used to "use oil", but not the LC's. If the oil level has dropped, There's either a leak, or an issue. The LC engine does not "Use oil"Because it used it. Nothing wrong with that.
Mine has. Hard ridden for 3.5k tour and I couldn't care less. It's down on the service fill and will be refilled on the 12k service.That's not normal for this Motor. The 1150's used to "use oil", but not the LC's. If the oil level has dropped, There's either a leak, or an issue. The LC engine does not "Use oil"
They do when you cain them...Period!That's not normal for this Motor. The 1150's used to "use oil", but not the LC's. If the oil level has dropped, There's either a leak, or an issue. The LC engine does not "Use oil"
Keep beasting it for the next 3 to four days of passes Leadfarmer and id almost guarantee you'd use a bit of oil mate!If I really gave mine a beasting, like up a mountain 2 up in 40° heat, it would lose a few drops of coolant from the weep hole, but never used any oil
It is on mine so far. Let's see if it does it again on my September tour. Either way, as long as it's not blowing blue smoke it doesn't matterPossibly. But its not normal to "use oil"
Enjoy your hard riding !
Mines the same, just been hooning around the Picos and Portugal a couple of weeks ago, topped it up about halfway through the tour with about 400ml.It is on mine so far. Let's see if it does it again on my September tour. Either way, as long as it's not blowing blue smoke it doesn't matter
Engines use oil!
Kept it for 8 years and swapped it for a 1300Keep beasting it for the next 3 to four days of passes Leadfarmer and id almost guarantee you'd use a bit of oil mate!![]()
Enjoy matey, their bloody great bikesKept it for 8 years and swapped it for a 1300
Just wish the weather would pick up now so I can get some more KMs on it
Enjoy matey, their bloody great bikes![]()
No worries, got some oil now so will see how it goesYep, absolutely love it
Sorry OP for the thread creep !
lol they do, just not as much as the hexheadsLow oil level. I think when it's been serviced last week they've put the bare minimum in. It has only shown when been riding enthusiasticallyIs the warning for low oil level or low oil pressure?
