Padmei Registered user Joined Mar 13, 2010 Messages 250 Reaction score 0 Location Nelson New Zealand May 16, 2011 #1 Are these unobtanium or something? Are they a standard size I can buy over here or are they special in some way?
Rob Farmer Well-known member UKGSer Subscriber Joined Feb 25, 2002 Messages 15,647 Reaction score 90 Location Vale of Belvoir May 16, 2011 #2 Is that Rocker box bolts or the ones for holding the rocker arms in place?
Padmei Registered user Joined Mar 13, 2010 Messages 250 Reaction score 0 Location Nelson New Zealand May 16, 2011 #3 Sorry the price caused instant shock I should have said tappet adjusting bolts Thanks forthe quick reply Rob
Rob Farmer Well-known member UKGSer Subscriber Joined Feb 25, 2002 Messages 15,647 Reaction score 90 Location Vale of Belvoir May 16, 2011 #4 They are expensive aren't they?
Padmei Registered user Joined Mar 13, 2010 Messages 250 Reaction score 0 Location Nelson New Zealand May 16, 2011 #5 So are they special as in size or is it they are made of something superstrong?Maybe I'll just take one to my local bolt supplier.
Rob Farmer Well-known member UKGSer Subscriber Joined Feb 25, 2002 Messages 15,647 Reaction score 90 Location Vale of Belvoir May 16, 2011 #6 Well they're nicely cup shaped and hardened to fit the push rod. I'll be very surprised if you can buy one from a nut and bolt supplier..
Flipfly Well-known member UKGSer Subscriber Joined May 26, 2006 Messages 15,023 Reaction score 248 Location Stoke on Trent May 16, 2011 #7 Rob Farmer said: Well they're nicely cup shaped and hardened to fit the push rod. I'll be very surprised if you can buy one from a nut and bolt supplier.. Click to expand... 100% Rob. The hardening will be totally different to a standard bolt as they aren't hardened for tensile strength, they'll be specifically case hardened so as not to wear. If new ones are too expensive, have a look at picking up some used ones
Padmei Registered user Joined Mar 13, 2010 Messages 250 Reaction score 0 Location Nelson New Zealand May 17, 2011 #8 Cheers guys
Redboots Member well-known UKGSer Subscriber Joined May 16, 2006 Messages 13,387 Reaction score 15,234 Location Deep in the Vosges du Nord May 17, 2011 #9 You could always get some of these if your flush lightweight adjusters John
