BegesRus
Riding to get MOT - the damed rubber split on the way!
With much help from my mate Les the job got done like this
Temp duck-tape removed
Remove rear wheel
Exhaust and collector box
Battery Box
Drain and remove Bevel Box
Clutch arm
Swinging arm
Para lever
Brake cable
The ofending item stripped
The swinging arm can be removed with the driveshaft insitu
Tie the bearings in place so as not to mix them
Clean up s/a ready for install
New boot being fitted
Slip s/a back into position
Like this
Install bearings each side
Pre-load the bearings
To correct Tourqe
Set gaps equal on each side - mine was 3.7mm
You have to do this repeatedly when you back off the torque to the final setting
Tighten the lock nuts
Fit the boot to the Gearbox - this takes patience to say the least - no grease - no hot water just keep at it! swearing helps a lot
Lube the splines and refit bevel box - a bit tricky to get engaged
Jobs done
Recheck all bolts are tight and set to toruqe
Hope this last for many years and it's an enormous job for a piddly part
My thanks to Les without his help I would be running round with duck tape!
Remove rear wheel
Battery Box
Clutch arm
Swinging arm
Para lever
Brake cable
Like this
To correct Tourqe
Jobs done
Thanks for taking the time and trouble.
- picking it up tomorrow.
