I might try that when I next need some chain lube.
I currently use Wurth high performance dry chain lube, and it's brilliant.
Worth is certainly a good name in the trade ... I have no experience of it/them.
The 'Castrol OR' is excellent. Doesn't fling off at all, at all at all
After a day on the bike, 180 to 200 miles the chain rollers are still bearing grease. It takes two or three days for them to turn shiny, when you just know that it's metal to metal contact
I probably over grease mine
Whenever I wash my 'bike, before I start I clean the chain with a good chain cleaner (O ring friendly) NOT WD40 .... wash my 'bike as normal, hosing down the chain. Then I might wipe the chain down with a rag soaked with WD40 (I actually use Putoline 1001 maintenance spray) but not soaked enough to get on the O rings. When finished spray with the Castrol OR (a few of us on here buy it by the box and divvy up)
Sounds like a long process, but it only takes minutes in reality
Ps .... I see that every bike on the MotoGP lineup were chain driven
