slip joints
dubster
some random place
Gents, refitting my Y-piece due to some leakage that was causing backfire. Was going to apply some copper grease, but though I'd ask first what everyone else uses? Cheers :thumb
Put the cat back and it won;t back fire
y piece and std can you can get some awesome bangs :-D
Shouldn;t be as bad with a remus and db killer tho
Don't have a cat to fit and don't want backfires either :eek
Yes and thanks, the std can will help, but the problem I want to remedy is that the y-piece doesn't fit snugly onto the header, as indicated by a carbon trace at the join :nenau
Was looking at that today in halfords, but instructions said 'not advised for exhaust systems'. Tim, do you have a certain brand you recommend?
Cheers :thumb2
Go to your local Exhaust fitter and see what they use.:thumb
When the instructions say 'Not Advised...ask yourself, why not?:D
Its because silicone is supposed to kill the Cat, as you have removed yours it wont affect you. Dont worry about special expensive silicone use a cheap £1 builder's clear silicone in a mastic gun. works wonders.
Exactly:thumb
Many thanks Tim and Warmshed. I've always been sceptical about believing what's written 'on the back of the packet', but it's certainly good to have some advice based upon real world experience. Cheers guys :thumb
Cheers .... :thumb2
I'm getting my rear end re-packed next week so when I push it back in I'll use silicone to stop the leaks ...... :cool:
You realize you may need surgury to remove the smile from your face?.
I use exhaust assembly paste on my as air leaks seems to be the cause of most popping and banging, I don't think the joints are suppose to slide anyroad....:blagblah
The Remus Y piece on my bike was a slightly smaller diameter that the cat outlet. I packed it out with aluminium from a old coke can wrapped round the end of the Y piece and used exhaust jointing compound to seal it.......still backfires the odd time though. I think the fuel injection fires unburnt fuel down the pipes on the overrun and these auto-ignite when the bike is ridden........enthusiastically:D
Doesn't silicone kill the O2 sensor? That said, for all I know you leave the O2 sensor screwed into the cat when you fit a Y-piece so same difference on a GS?
My y-piece has a sensor so that makes me wonder about using standard silicone, they ain't cheap to replace :eek:
I've slapped some copper grease on which seems to be doing the job for now but if it leaks again I'll go the silicone route.
Thanks for the advice gents :thumb
