Stelvio ordered
Lovely bike health to enjoy it as they say in these parts (y)
Enjoy the new bike Clifton, looks good (y)
See what you mean about the stickers, I normally leave them alone but that one on the radiator cowl is a tad unfortunate
Appreciate it, leadfarmer! I just feel the stickers look like a regulatory CYA, and as they age can further discolour. If removed at that point it leaves an unfaded area of plastic or paint, so I take them all off right away.
Thank you!
Lovely bike.......enjoy
or as we say in Ireland ........"well wear"
Sent with a Zen10
This afternoon I took the Stelvio out for the first time, accompanied by Jim on his KTM1190. Weather was clear and had warmed to 45 (7c) when I left at noon and got to the mid 50's for a while. The bike had 1 mile when I left and when I filled up 7 miles from the house on the return, the odometer showed 192 with the low fuel light having been on the last 12 miles. We were on paved primary and secondary roads at 30-70mph indicated speeds with a 20 mile Interstate jaunt at 80 indicated (about 75 actual). Heated grips were on I or II (out of III) the entire time and worked well.
I'm 5'-11", 195#, with a 32" inseam and the ergonomics fit me well, if anything I could wish the seat to be maybe both 1/2"-1" taller and rearward for my achy old knees, but the seat itself is fairly comfortable and flat for a stock one. Handlebars are located perfectly and the windscreen and overall wind management is very good.
The engine is delightful and pulls well even when I tried it down at 2,000 rpm in 4th. Fueling is spot on with no flat spots or hesitations anywhere. The throttle is better than on any other bike I've experienced recently with no abruptness at all, very smooth. No vibration or buzzing, at least at any speeds today. The bike idles fairly high at 1400 but Jim's KTM idles about the same so high idling is pretty common anymore.
The gearbox and wet clutch combine to give a light lurch and bang when selecting 1st gear, similar to a modern Harley. Jim's KTM does as well but maybe not quite as abrupt. It's something wet clutch bikes just do, some more so than others. Shifting up and down through the gears (no quick shifter) was nice and no missed shifts so the gearbox works well very, about the same as a Wethead BMW. My only slight gripe is the ratios seem closer than need be with 5th and 6th being a little short. 60 mph (actual) corresponds to 4,000 rpm which seems a little high for a bike with this much power and 6 gears. I wouldn't want 1st any taller, if anything it could be a bit lower, on a bike like this so it's not the FD ratio it's the gearbox ratios. It was fine for the riding I did today but riding in areas with higher speeds I just feel a taller 6th would be nice. I should add it doesn't need a taller gear to keep below an RPM where vibrations begin, at least to 80 mph.
The handling is fairly light and very neutral, it doesn't fall in nor does it need pushed. As a matter of fact I didn't even think about the handling until we'd been riding a while. Like seats I guess, if you don't think about it, it's probably pretty good. Going around a long 270* curved entrance ramp I am always making minor corrections to maintain the line through that curve, but it just followed that curve like it was on a track.
Brakes are strong with a very lineal feel. Surprisingly the rear is particularly good requiring little effort as well. Rear brakes on some motorcycles, like my V85TT and Tenere 700, require a healthy press yet still seem weak. Not so on the Stelvio.
The gravel/dirt road I live on had the front top part of the fairing jiggling around some which of course could be slightly heard as well. Both the instruments and windshield system mount to this area and I can see it all moving around some, more than I think it should. My hunch is it might get worse if ridden a lot on rough roads but maybe not, we'll see. This is really my only build quality complaint and the V85TT cowling area doesn't do this.
I want to get some kind of panniers for sure, preferably top load aluminium. I'll probably also do something with the seat, maybe just fit a sheep skin for longer rides or possibly replace it with an aftermarket one (if someone comes out with one). The windshield seems fine. The exhaust sounds great to my ear and there's no popping so I wouldn't change it if someone gave me one! All in all I'm quite happy with it, too bad about the dull paint finish.
Thanks for that Clifton. Pity about the gearing, we shall see. I'm also not a lover of matt paint finishes and will be getting mine lacquered asap. Keep reporting your thoughts and enjoy.
Nice review Clifton. Fabulous looking bike. Enjoy. 👍
Nice write up.
I’m not surprised you wish the seat was a bit taller.
I found it surprisingly cramped when I sat on one and I’m 6’1" with 34" inside leg.
Sent from my N65
Thanks for taking the time to do the write up. Ergos sound perfect for me as I'm 5'9 with a 31 inch inseam. Local dealer is putting on a demo in March 👍
Stelvio uses the same gearing as the Mandello, the only difference being the rear tyre but they're practically the same circumstance. To me it's one of those things that the sportier CR gearing works fine, it's just that I feel wide ratios would have been even better on an adventure motorcycle. Unfortunately most manufacturers feel that changing ratios between bikes is too difficult so we get one box fits all.
The bike will fit quite a wide range of riders with the easily changed handlebars and the available lower and taller seats.
I hope Pyramid comes up with a proper coverage rear inner mudguard and front extender soon!
Thank you, Paul. Now that the bikes are on the road there should be proper reviews coming along pretty soon.
Interesting, my Mandello is doing 70 at 4000rpm.
OK then I've made a mistake. Either I misread the GPS or tachometer, or the Mandello has a different 6th gear or FD ratio than the Stelvio. I'll check again. The tyre sizes are different but the difference in circumference is so minuscule (.8% difference) they are essentially the same.
190/55 - 17 = 79.2" circumference.
170/60 - 17 = 78.6" circumference.
I'll look in the manual and report back with the Stelvio gear and FD ratios.
Pyramid are pretty quick responding to new model releases although they (or anyone else) have yet to come up with anything for the rear for the Mandello. I imagine the Stelvio would be the same fitment for anything that does become available.
I’d be getting the paintwork lacquered…I hate these matt/satin/dull finishes.
first job on the list for me
I just got a quote to clear coat, with me taking the 4 panels to them. After getting the quote :eek: I think the matte is looking much better!
I also tried to determine exactly what the speed was on the GPS when the tach was at 4,000 rpm. I'm not sure exactly where the "needle" is on the tach but depending where it is, it appears that 4,000 could be anywhere from 62 to 65 mph, which showed on the speedometer as anywhere between 64-68.
After riding again today I could care less about the matte clear or what rpm it's turning because the bike is that delightful to ride. I'm beyond the "have I made the right decision" phase, moving on to "I really like this motorcycle" phase.
I did decide to order a tall comfort seat taking advantage of the dealer's "15% off accessories when picking up a new motorcycle" deal. The dealer said they were backordered now but were due in the country the 20th. I told them to put an oil filter (complete with any required o-rings, washers, or gasket) in with the seat when shipping it to me.
