vilguy
Thought i would add another thread on these :-
Well i broke my eom heated grips messing around with handlebars etc and so needed a new set... put some oxfords on but couldnt get on with them as i didnt like the way the wires come out of them in a big blob of rubber.
So i got these from winding roads, Arrived the next day which was a brilliant service.
installed them quite quickly and hooked them up to the bmw grip controller rather than use the toggle switch, tried to get them to work but couldnt until today, didnt realise id blown the fuse.
Anyways ... good god they get hot... and fast! on high setting they get very hot within just 2 minutes!
Bad point - dont use these with renthal "medium" grips... the heat from the symtecs were too much for the renthal grips and they split clean open!!!
Just need to get a new set of grips sorted, some slightly thicker ones that will cope with the heat a bit better. But can honestly say these are THE best heated grips i have ever had. I much prefer them over the OEM set.
Paul
Paul
