Yep!
hi tony
i have been doing a bit of digging with regards to the exhaust valve. the technition i spoke to say its in there to help mid range torque and nothing else. he says if you disconect it you will loose a very very small amount of mid torque but it will become a little louder . as anyone tried it yet ?
The same thing my bmw-mechanic say's, as does the manual btw...
And when I say manual I mean the Hp2S's Repair manual CD.
It say's:
***"Synchronising servomotor and exhaust-flow control valve with BMW Motorrad diagnostic system
-In the BMW Motorrad diagnostic system, select "Toolbox, engine electronics BMS-K".
- Run the "Synchronise servomotor and exhaust-flow control valve" routine.
- Follow the instructions issued by the BMW Motorrad diagnostic system."***
The interesting part is that it refers to the valve as "exhaust-flow control valve"!
Also, if we take a look at the specifications for the new S1000RR we find this in the PDF-file released by BMW this weekend:
"Innovative exhaust system with interference pipe butterflies for optimum power and performance.
Made completely of stainless steel, the exhaust system featured by the S 1000 RR is designed consistently for optimum power and performance. It works according to the 4-in-2-in-1 principle with four individual manifolds of equal length first merging into two pipes beneath the engine block and then extending into a large-volume pre-silencer. From there the exhaust emissions flow through a very short and dynamically designed rear-end silencer to the outside.
A homogeneous power and torque curve ensuring optimum rideability is acknowledged as the requirement for sporting performance on the road and fast lap times on the track. Precisely this is why the exhaust system featured on the S 1000 RR comes with two fully controlled interference pipe butterflies housed in two connection pipes for the two outer and two inner manifolds, in the immediate vicinity of the exhaust ducts. As a function of various parameters such as engine speed and the position of the throttle butterfly, an adjuster opens or closes these flaps, allowing exhaust gas to flow freely between the two manifolds or, respectively, interrupting the flow of gas. This coordinates the sequence of oscillations in the exhaust gas mass flow, reducing exhaust gas counter-pressure at the decisive point (like on a racing muffler) and increasing the cylinder charge accordingly.
This factor alone makes a significant contribution to the very high standard of
homogenous overall performance offered by the S 1000 RR. "
With this info it's not far fetched that BMW would've tried this on the HP2S before they used it on the S1000RR, in other words the butterfly-valve on the HP2S has the same function as the one on the S1000RR stated above (only the S1000RR has a more refined exhaust).
Back to the HP2S valve. I've tried to run it with the wire disconected and didn't feel much change, but a few Nm of torque wouldn't be felt, only measured on a dyno. And also, I couldn't hear much difference either, but then I was ON the bike!
/J
