76,000km now, I get a slight pull-asymmetry with the stock cables on some spots of rpms that the vacuum gauge confirms. Already bought a spare set, I'll put them on soon and see if I get a near-perfect synchronization over the RPMs.
I reckon it's the induced asymmetry in the TB sync they ought to be replaced after around every 50Kkm (according to the manual), IF you look for the best possible sync possible that is. If you're OK with slight vibrations then you're OK to go with the original cables that will probably work forever by just properly lubing and maintaining them.
