Throttle Cables
Hoff
Old Submariner
Denmead, Hants
Can some wise sage on this forum answer a question for me?
Do you lubricate throttle cables on a 1200GS twin cam? I have read somewhere not to lubricate but my Haynes says Yes!
Thanks in advance.
They are lined so no need to lube them
Iv had so many jap bikes,cars,vans & cycles with lined cables that seize up due to water ingress & corrosion,GT85 good cos its got teflon or I use chainlube very good on clutch cables makes them silky smooth,if your cables feel stiff lube them if their free & your happy dont.
Lubing the cables is a bad idea. The Teflon lining will cause them to get gummed up with dirt if you lube them and get very sticky!
Jim :cool:
