BOLLOCKS!!!!!
FFS!
I've only dropped the rebuilt gearbox while fitting it! I'd even put a load of bubble wrap on the floor. I was balancing the gearbox while connecting the neutral switch wires, dropped the gearbox and then batted it away from the bubble wrap onto the concrete floor and into the wall.
The upshot is my freshly rebuilt gearbox now has a broken end cover and a chunk out of the main case. I've spare end covers and cases but this is a kickstart gearbox so the only options to buy a new cover.
I've fitted loads of gearboxes over the years with no problems at all..so all told this gearbox will have cost the best part of a grand - New input shaft, bearings, seals and a circlip output shaft and obviously a new end cover.
.Am I right in thinking the bit missing from the end over just holds the driveshaft gaiter, and isn't under much stress so could be amenable to a chemical metal or araldide fix, or would the heat cause the latter to crack in time? Can the missing piece from main case be welded back in, most of the circumference of the hole is still intact and presumably able to retain the bolt that goes through it? Why not, as already suggested earlier, alloy weld the damaged bits back on?
The upshot to all this damage is that chancers like myself, who might know the theory but not have enough hands on practice with some jobs can feel better when we make mistakes that make us wonder would it not have been cheaper to farm the work out.
Ain't she purdy?
