Hi all, had an oil leak from the front cover, and removed re sealed not too many probs. My problem regards the timing. I have set the engine with the ost? think thats what it says through the window, but how do i know what position the hall sensor should be set at, and if it is wrong will it still start? Or will it start but just run roughly, and if the hall sensor is knackered, will it run roughly or not at all?????? I'm feeling a bit thick at the moment!!!! Have got a multimeter but what setting do i need it on to test if the hall sensor timing is set?????
many thanks in advance
Silver Fox
Silver Fox
