40K, 2007 R1200GSA owned from new.
Just been through a fuel pump failure outlined in Roddy L's post in this section, now we have a further "opportunity" to fix!
During the warranty period this bike had an EWS changed. Can't remember the circumstances, vaguely remember a non start at a fuel station in Somerset but could have been a recall. I mention this just for historical background.
Today, on a ride to a meet up, (Fishguard to Cardigan) the bike cut out several times momentarily with the warning triangle lit then continued with the triangle extinguished as normal.
On the ride home this happened 1/2 dozen times at least, with two occasions of complete failure and EWS! showing.
Now, I know what the EWS is, where it is, what it does and how it interacts with the keys.
In the experience of the collective:
1) Is the failure of the EWS unit a go/no go or will it perform intermittently?
2) Can replacement be done by a semi competent idiot, (me)?
2) If I replace it will it recognize the existing keys or does that have to be programmed by a dealer?
Having read other EWS posts on here I wonder if I have a wiring problem between the EWS unit and the ECU (not my strongest skill......). Any suggestions on PIN numbers etc for chasing this down would be greatly appreciated.
I have a GS911 but have not yet plugged it in to read fault codes.
TIA
Simon.
TIA
Simon.
Could you not bring the laptop to the bike?!
