TKC problem.
Wear pattern is a bit weird, but 6k on the right hand side of the road would explain some but not the splits. Anybody had the same ?
Front after 10.5k miles (old tyre is on the right).
Tim
That wear pattern is normal - not sure about the splits though
Tim
good job you said which tyre was which, i'd never have known :D
6500 from a rear!!!! I got 1700 to 3000 and about 7000 from a front, I dont get 6500 from a Tourance, thats about 5000, only Distanzias have come close to 6500.
Pete A
Stop faggoting about with mostly off road tyres on tarmac and fit some road going rubber... :tosser
After playing around with tyre and pressures over the years.This is due to the tyre being under inflated which alloys the blocks of tread to rotate and wear uneven. The split mite just be a crook tyre out of the batch. (it happens)
