I have a Givi Trekker 52, plenty big enough. If you're thinking of Givi, also do a search for Kappa, pretty much the same but lower budget so you'll get almost identical stuff and will fit the same plates. Another tip, do a search EU wide on fleabay and you'll see the prices are a lot lower if you buy from Italy, I've done this several times successfully and saved quite a lot of cash even allowing for higher postage.
