Hammam Registered user Joined Dec 9, 2010 Messages 329 Reaction score 0 Location Montreal, Canada Mar 9, 2011 #1 I am about to buy Touratech crashbars for my 1200 GS. Anyone here have installed them themselves? Is it straightforward? I am not very proficient at DIY, but I can handle a screwdriver and pliers. Thank you.
Davy F Registered user Joined Jun 7, 2005 Messages 7,456 Reaction score 17 Location 36th Ulster Divison Mar 10, 2011 #2 Dead easy, just remember to re-tighten after a few miles of bedding in.
XRM Guest Mar 10, 2011 #3 Had to do a bit of grinding on mine as the upper LH bracket was touching the oil line on the LHS of the engine. Apart from that - no problem. Just keep an eye on the gap when you tighten the bolts.
Davy F Registered user Joined Jun 7, 2005 Messages 7,456 Reaction score 17 Location 36th Ulster Divison Mar 10, 2011 #4 XRM said: Had to do a bit of grinding on mine as the upper LH bracket was touching the oil line on the LHS of the engine. Click to expand... I believe that that slight flaw has now been addressed. If not, it's an easy fix. This is what you should end up with.
