Is it possible to set the TPS voltage using a meter on a 1200 as I have done before on 1150's
The reason I want to check is that at just a whiff of throttle feels like the bike will not run smoothly as if the ECU thinks the throttle is already shut.
I have spent some time setting up the throttle bodies using a carb balancer at 2500 rpm, and general performance is really smooth and progressive.
